I'm in the process of fitting an OEM hardtop to my '66 convertible that has a 'soft top only' deck lid (no existing provisions for h/t). I have all the hardware, hole sizes, etc. Looking for advice on several matters.
Doing a trial fit (front latches closed with the aft bow carraige bolts removed) gives me 1/4 to 3/8" of clearance between the deck lid & hardtop wx strip along the L & R sides behind the windows. I'm assuming that I should have an assistant press down on the top to compress the side wx strips while I locate the hole centers for the side bracket fasteners. Is that correct? Maybe I have to adjust my deck lid height somewhat, as well?
How can I most accurately transfer the correct aft bow hole locations from the hardtop to the deck lid? I assume that the forward latches and side bracket fasteners be installed and tight to do this, but the location is inaccessible.
Once I've got the holes drilled and hardware installed, what's the proper sequence to install the top? The owners guide is not clear -- particularly regarding installing the nuts/washers on the aft bow carraige bolts.
Finally, what is the purpose of those small nylon 'bumpers' that go into the blind hole in the aft bow carraige bolts?
