Last week I reported in thread that I had repaired my grinding starter/no start when hot.Today after I let it idle for a while in the driveway and then turned it off the problem reoccured.I replaced the ground wire from the block to the frame last week and this temporarily fixed the problem.When you do manage to get it started it runs differently,so I checked the timing.it was off.I have hei wich grounds threw the block to the frame.I suspect the bad ground would be causing this as well.Am i correct?The bigger question is why is my car eating ground cables?After replaing the ground cable last week the starter sounded amazingly quite and the car actually seemed to run better.Am I crazy?What is a permanent repair?I dont mind if it wont pass judging.
