58 Grille Assembly - NCRS Discussion Boards
58 Grille Assembly
  • Marc W.
    • February 1, 2005
    • 53
    58 Grille Assembly
    I had my 58 judged in Orlando in Jan at the NCRS regional meeting.The exterior judge took off points beside Blackout/wiring/clips/gromments-front radiator area.He wrote in pencil missing 2 blocks.What did he mean?
  • David Dawdy
    Re: 58 Grille Assembly
    Marc -
    Only he can answer that, perhaps he waqs referencing the two plactic 'blocks' that are the wiring harness connections for the lamp assemblies that clip into the spring clips at the hood opening area.
    • Marc W.
      • February 1, 2005
      • 53
      Thanks for the info on the two blocks.
      Do you know where I can find a photo of this area and the two blocks you have described?
      • David Dawdy
        Marc -
        Try Noland Adams volume one, I am sure there is a shot somewhere, if not perhaps some with a digital camera and knows how to post a photo can assist, else I can take a photo and send it to you.
