i hooked up the choke on my L72 and found that in the cold setting the carb closes about 80% but not all the way. the limit seems to be set by a tang on the heater coil peventing the rod to extend enough to close the butterfly all the way, is this correct? bill
choke on L72 question
Re: choke on L72 question
Bill
I have run into this condition more than once over the years.
Reccommend you make sure the choke rod and coil has no binding
condition when not connected to the choke plate link.Also make
sure the choke plate moves freely.Do this on a cold engine,if
ok complete your choke rod adjustment.Final test movement of
the assembly when set on the high step of the fast idle cam.
Reguards, mike- Top
