C -1 Intake Manifold Gasket Sealer - NCRS Discussion Boards
  • Jimmy J.
    • May 31, 1988
    • 304
    My engine builder says I do not need any RTV sealer around the water passages on my 283/245, what is the opinion of this board? Thanks in advance, Jimmy
  • John M.
    • January 1, 1999
    • 1553
    Re: C -1 Intake Manifold Gasket Sealer
    I never use any. If the surfaces are true, than it should not be necessary.
    Regards, John McGraw
    • Jim D.
      • 2882
      I don't use it around the water passages but throw away those manifold end seals and use RTV instead.
      • Terry R.
        • March 1, 2005
        • 359
        Don't throw the end seals away if you're going to show it.
        • Jim D.
          • 2882
          Good point. If you're not going to have it judged - throw them away.
          • Dave Suesz
