C2 redline tires - NCRS Discussion Boards
C2 redline tires
  • Larry S.
    • March 11, 2007
    • 457
    C2 redline tires
    Is it permitted for you guys to recommend a redline tire brand/supplier? Since they're kind of pricey, I don't want to hear "You bought that brand? They're junk." Does anyone sell a 215 instead of a 205, and is this a good idea? Thanks.
  • Joe R.
    • March 1, 2002
    • 1356
    Re: C2 redline tires
    Are you looking for a correct reproduction bias ply tire to use for judging, or a good redline radial for driving?
    • Larry S.
      • March 11, 2007
      • 457
      Joe, my car is a weekend driver. I have whitewall radials right now, but they'll need replacing soon. Do you have a brand and source you can recommend? Thanks.
      • Joe R.
        • March 1, 2002
        • 1356
        Hi Larry:
        Sorry, but I am only knowledgeable about the reproduction bias ply redlines that would be used for judging. These are NOT good tires for everyday driving.
        I have seen other postings here on the tech board regarding redline radials for driving. You could probably find those postings in the achives by searching on the words "redline" and "radial," or perhaps "red," "line" and "radial."
        I believe there is at least one company that make redline radial tires. Also, there is a company called Diamondback that takes standard commercial radial tires and applies a redline sidewall to them. You could probably find them on the internet or by searching the archives.
        • KEN BUTCHER
          Hi Larry, try www.universaltire.com they seem to have a good size selection.
          Ken.
          • Jack W.
            • August 31, 2000
            • 358
            Driver redlines, goldines etc - I would strongly urge you to visit with Diamond back Tire - they smooth the sidewall of a modern day radial tire, and apply the [correct width] redline or goldline [or blueline even] as you direct.
            215/70R15 here, in Goldline, from Diamond Back.
            Diamond Back Tire
            • Gerard F.
              • June 30, 2004
              • 3803
              Larry,
              I'm happy with my Coker Classics in 205/75R15 for highway driving on my 67. They make them in redline and goldline. They are M&S and are like the old Michelin X's.
              They tell me they are not the best for handling but I'm not into slalom runs, and can't tell the difference. They are slightly larger than the 775 stock tire, and I have found a 2.3% correction to speedometer and odometer readings based upon actual highway mileage by post mile markers. My speedometer and odometer will read slower and less mileage by that percent.
              For the price, they are a good driver tire and look good on a C2. However, if you judge with them they are a standard deduct on originality of 75%, that's 24 points.
              Jerry Fuccillo
              #42179
              Jerry Fuccillo
