Have finished replacing my core support, radiator etc. In the process I had to pull the horns and the horn relay off the core support. I did not pull any of the wiring off the horn relay but just moved it aside. I did pull the connectors off the horns. I have remounted the relay and wired up (but not mounted the horns) to test and when I press on the horn button I just get clicking sounds from the horn relay. They were working before I started. I am not too knowledgeable electrically. Any ideas? Any good sources for info? My 67 service manual doesn't seem to have much info other than the wiring diagram. Would the horns not work if they were wired up on the wrong sides?
Thanks for any help!
Nick
Nick
