C2 Ft. Parking Lights gasket colors - NCRS Discussion Boards
  • Alan Drake
    While cleaning the front parking lights I noticed that the gasket under the lens was a light gray color and little dirty. Since I was having a hard time cleaning the gaskets and had an order going out - I ordered 2. The replacement gaskets were black not light gray. Some repro houses do have the grays, however.
    A look at the 3 NOS lights I have all show a black gasket. SO0oo for a Mar64 car what would be the correct color and more important what is the story behind the color.
    Other Comment;
    A little update on my past questions on the parking light. It appears that 63 had the black wire cover that also covered the connector (its one piece). Additionally the lens screws had holes which came through to the back - after that a blind hole was cast into the light. It was felt that the black wire cover with the boot end was also dropped at that time. (Info from Michael Hanson) However mine has the blind holes and booted cover. Yet another 63/64 question.
    Thanks Alan
  • Terry D.
    • May 31, 1987
    • 2690
    Re: C2 Ft. Parking Lights gasket colors
    Tha General bought from more than one supplier, they didn't stop production cause they ran out of black gaskets. Got to remember they were not worried about restoration, they were worried about production!
    • Alan Drake
      Have said the same thing many a time, however was expecting an answer that the gray were early, say in the 63 - part of 65 range. Do you know if two sources were used from day "1" ?? That would be a valid answer. Thanks
