1970 Brake Bleeders - NCRS Discussion Boards
1970 Brake Bleeders
  • Stephen B.
    • April 1, 1988
    • 876
    1970 Brake Bleeders
    On page 104 of the 1970 to 72 judging manual, the manual states that the brake bleeders are zinc plated. Is this yellow in color or silver?
    Re: 1970 Brake Bleeders
    Zinc is silver in color. If after plating, the part is dipped in chromatic acid, it takes on either a yellow 'rainbow' or dull gold hue (depends on the strength of the chromatic acid and the time the part is washed). That is called a dichromate, gold dichromate or irridite finish.
    It's done to enhance the longevity of the cad/zinc plating. The gold tone is typically a THIN coating that's easy to remove by handling, polishing or simple acid etch to get to the underlying cad/zinc...
      Bunky----
      The bleeders were "silver" zinc.
        NOS Example
        Here's an example of an NOS bleeder valve:
        • Wayne M.
          • March 1, 1980
          • 6414
          When did they go from 5/16" hex to 3/8" ?
          This is probably an original 5/16" hex bleeder on my late '65 "905" inboard rear caliper, removed from car in 1989.
            Re: When did they go from 5/16" hex to 3/8" ?
            Wayne----
            I believe that the change occurred sometime during the 1969 model year. They changed again during the 1981 model year (to metric).
