Chemical paint stripping - NCRS Discussion Boards
  • Michael L.
    • July 31, 2005
    • 562
    Having the final chore of removing 3 layers of paint on my '55, I used a fiberglass safe stripper on the door jambs and dash. The instuctions call for a plastic scraper to remove the sludge, I found a plain old wooden popsicle stick was super for all the intricate curves and corners in those areas. If gloved up properly to avoid burns, the stick also makes a good wide scraper as well. No nicks or scrapes on the glass either. Came off slick.
  • Ray C.
    • June 30, 2001
    • 1132
    Re: Chemical paint stripping
    Mike, The plastic spreaders for body fillers also work very well. Make sure that you wash the area that was stripped with warm soapy water. I used a stiff bristle brush for this process. I then used Scotch Brite pads soaked in lacquer thinner and then washed the car for a second time.
    Good luck
    Ray #36314
    Ray Carney
    1961 Sateen Silver 270-HP
    1961 Fawn Beige 315-HP
    • Mike B.
      • August 31, 2006
      • 54
      Can you tell us the product name?
