I've had an ongoing issue w/ my '70 L46 Corvette:
1. After I bought car, tank developed a leak. I replaced tank with a OEL tank from Quantra.
2. After about 3 weeks, I noticed the tank had collapsed in on itself. This car is supposed to use the sealed, non-vented type cap, which it had.
3. The only explanation I got, was that the relief valve that's built into the tank was defective. There has been debate on whether this valve is designed to relieve pressure, or vacuum, or both. I still don't know.
4. I've had a new tank in it for awhile, and switched to a vented cap, thinking that that might avoid the previous situation. So far, it hasn't collapsed, however:
5. I'm getting a strong gas smell in my garage after I've driven it. It was warm and sunny the other day..When I removed the cap, I got a rushing-air sound and it was definitely pressure and not vacuum.
So, what's the deal? Why did one tank have a vacuum condition, and now this one has a pressure condition? And why am I getting a reeking gas smell? It's not the carb; I've checked that.
Thanks -
confused Mark
Thanks -
confused Mark
