1953-55 Automatic used #3706325 knob indicating P,N,D,L,R. Was screwed on to shift shaft and had a chrome lock nut.
1955 3 speed used a stainless steel retainer ( a pressed out piece) repro's are solid cast piece chromed
1956 3 speed & automatics (early) used a ZINC indicator plate (was vary heavy)
1956 second design and up to 1962 used a aluminum plate
56-58 used #3728940
59-62 used #3757865
The zinc plate is a vary rare item to locate that no one repro's but it's only for a 56 early Corvette. All repro plates I've seen are different then original in the look of the (numbers) never seen the differences judged that's why I call this trivia.
56-58 used #3728940
59-62 used #3757865
