are BB and SB forks the same? - NCRS Discussion Boards
  • Bill S.
    • January 31, 2007
    • 396
    i am using the fork off a SB bell housing. i believe the housing was a 443 10". the fork does not seem to line up right on my 444 11" housing. the bearing seems off center.
  • Bill S.
    • January 31, 2007
    • 396
    Re: are BB and SB forks the same?
    make tha a 403 bell housing the fork is from
      Bill------
      The clutch forks are the same for small block and big block, regardless of bellhousing. Fork GM #3887177 was used for all 1966-81 Corvettes. It is SERVICE for all 64-65, too.
      • Bill S.
        • January 31, 2007
        • 396
        joe, what could be wrong?
        i bolted up the trans and housing on my bench with the fork in place. when i tighten it up and check the bearing it is bound up on the input shaft. it seems like the alignment of the fork is off. should i adjust the ball stud to center it more. the bearing i bought is fit to the input shaft and slides back and forth when i just put the bearing over the shaft. any thoughts? thanks,bill
        • Clem Z.
          • January 1, 2006
          • 9427
          do you have the TO bearing installed
          correctly on the fork? the spring goes INSIDE the TO bearing groove
          • Bill S.
            • January 31, 2007
            • 396
            got it! thanks guys
            boy do i feel stupid. had to drive down to my shop to see,its been about 25 yrs. since i did this last. so it just kinda of balances there till all goes together? thanks bill
            • Stephen L.
              • May 31, 1984
              • 3148
              Re: got it! thanks guys
              Photo of correct clutch throw out bearing installation
              Incorrect mounting
              • Philip C.
                • December 1, 1984
                • 1117
                Sorry SteveI think the bottom photo is wrong
                The fork goes inside the bearing. (Unless I have been do it wrong for alot of years)Phil 8063
                • Philip C.
                  • December 1, 1984
                  • 1117
                  Sorry again I didnt arrow down on photo *NM*
                  • Stephen L.
                    • May 31, 1984
                    • 3148
                    Re: Sorry SteveI think the bottom photo is wrong
                    The bottom photo says INCORRECT MOUNTING.... Whats wrong with it? Just trying to show how it looks when incorrect. The top photo although blurry, shows a correct mount. Didn't realize the blurry photo until after I'd put things together so I couldn't retake it....
                    • Philip C.
                      • December 1, 1984
                      • 1117
                      Steve I guess you didnt see my second post
                      a couple of minutes later. When you click on the photo its larger than the frame but the photo of the whole fork fits, I didnt arrow down to and see your note of the blue box. Phil 8063
                      • Clem Z.
                        • January 1, 2006
                        • 9427
                        you guys drinking again????? *NM*
                          Re: do you have the TO bearing installed
                          Like this:
                          • Terry F.
                            • September 30, 1992
                            • 2061
                            Spoons are the same....not sure about forks though.
                            Sorry....I couldn't help myself
