I just had my cluster restored. It's back in and everything now works as expected - except for my temp gauge.
Gauge used to read about 170 deg when warm. Now reads about 140 - which I know is incorrect. I realize these gauges are not supposed to be accurate at normal temps - only in the danger zone.
At 40 ohms to ground - the gauge reads just past 250 deg - which seems right, at 80 ohms - it reads about 180 deg - whish is low - I expected 210.
Do I have a gauge calibration problem - or is this behaviour within normaly expectd parameters?
