Around my entire 58, I've only found 6 clutch head bolts holding the hinge and the door of the seat separator, but believe there may originally have been more used around the car. Where should others be found around the car, and were they actually found securing the hinge and seat separator door in place?
thanks in advance, Steve
Steve, recommend getting the '58 Judges Manual from the NCRS store, which will tell you how many clutch heads were used in the seat separator and other locations such as in the trunk. Good luck, Gary....
thanks guys. I actually went to the Paragon parts book and put in clutch head and looked at all the locations that they sell them for---should have done that before posting the question--but came up with the hood support to the hood ledge, the hood release cable, front splash shields, the headlamp housing to the fender, the horn contact, the lower fan shroud, and the seat separator catch and hinges. Hopes this helps others.
