Dates on window are As-2 LY dot 15 M74 the other is same but JY.The papers in my book said the drivers side was replaced. dates OK?Pulled spaire tire down it has a paper tag that was molded into the rubber
#?458 also MJU2 DXA 192 what are the #s for? Wheel weight "not micro"
it is 1/2 14 1/2 there is a circle around the 14 original? AIR filter JM said 212 cw or 329 cw ther is no way this will fit.On the side of cleaner it has a paper tag AC 329c it is 1/3 of the size.Passenger wheel well in the front has chalk marks in the sign of a "T" any help?Spark plugs wires are Packard TV 20-72.Water pump will be here Wed. Bill said Hi.He will not be here in june.As you know I had the trim rings buffed still a little hazy but much shinnier I like 'm.Bad ? or go looking at swap show and look for used. on or off line?
Either way I want to say I'm sorry for my actions the other day! Sorry.
