1959 dual quads - NCRS Discussion Boards
1959 dual quads
  • James O.
    • November 1, 1985
    • 160
    1959 dual quads
    in trying to determine the correct casting codes on 1959 270 h.p. dual quads. i believe the tops are 6-1299 but how can you tell if the bases and center bodies are correct? how do you differentiate between long counterweights and short?
    Re: 1959 dual quads
    james----
    Yes, the air horns (tops) of both carbs should be 6-1299. The float bowl (main body) should be either 0-049 or 0-1049. The throttle bodies (bases) MAY be marked 1-1485S, front, and 1-1488S, rear.
    Long or short counterweights? I can't help.
    • William C.
      • May 31, 1975
      • 6037
      Re: 1959 dual quads
      The distance from the end of the weight to end of the shaft is 1 21/32 inch on the "long" version. The short version is 1 13/32 fron the end of the weight to the end of the lever. This is all in the judgin Guide, a very handy reference to have...
      Bill Clupper #618
