Jerry Bramlett responded to my question about bleeding the brakes earlier today. He mentioned that pressure bleeding with an external pressurized resevoir will do the trick. Jerry, or any other of you smart guys, where would I find this tool and how do you use it. Is it connected to the m/c or back at the calipers?
Another thought while I am at it. I have never had this kind of trouble bleeding brakes on any of my other cars. I did read, today, in my corvette restoration book that it is possible that the rubber hose from the end of the steel brake line going into the caliper may be worn out. This would cause the hose to expand when the the fluid is pressurized. Has anybody heard of this actually happening? It seems unlikely due to the fact that the rubber is so short.
Thanks for all of your help gentlemen.
