It seems like we have solved the C3 Blues mistery. At the end it was the carb. gasket causing the problems. It was a thin type which resulted in not blocking the exhaust bypass port effectively causing hot air to blow into the carb. Using a thicker (and therefore more stiffer) type the hot air is blocked resulting in normal behaviour of the fuel system.
Thanks all for helping me out (especially Jack Humphrey for putting me on the right track and Sander for helping me out with all the pratical details) with all your suggestions and tips.
I wouldn't know how to maintain and drive these cars without you all!!!
greetings from windmill, tulip, cheese and wooden shoe country,
Rob.
Rob.
