I've rebuilt a good dozen or more 62 7360 units---never an issue.
This 4520 unit has me scratching my head.
The scenario:
Almost 3 years ago an engine connecting rod broke just below the wrist pin and took out the block/cam/crank/pan, etc. (realaly trashed everything but the heads). At that time, when I removed the FI unit it ran well, but was a little skittish about starting after sitting for a period of time. (More difficult than should be expected) I drained the unit of fuel.
I now have the new motor in, and timing is right, valves are set right, etc.
It is much harder to start. In fact, after fighting it to get anything from it, eventually it will start and run 5-10 seconds and die. NOT BALLAST RESISTOR RELATED. After about 20 or so repetitions of that, I can finally keep it running,and it runs strong.
Let it sit for a day, and it is the same fight all over again to get it to start.
My amateur diagnosis is that it is choke-related (and I have been wrong many times before). I have much FI manuals/documents, etc---but most/all deal with the 4360 unit rather than the 4520. I'm struggling a little bit with choke and cold start theory. Take away the microswith and give a good old cranking signal valve, and I'm much more competent.
Anybody got any good ideas for what to look at/for when I get the courage to tear into it?
Thanks in advance!
The scenario:
Thanks in advance!
