Clarification is welcome! So, if working with a standard hydraulic lifter, if you tighten it just untill the play is taken out of the push rod/rocker arm, is that ZERO lash?
If you crank it down 1/2 turn beyond the about point, is that consider a preload?
Sorry to make anyone cringe about this.
I am wondering about the technique of using a standard lifter and adjusting it to just when the play comes out of the rocker (I could totally be misunderstanding this method). My understanding is that it assumes the lifter will completely pump up at high RPM and act essentially as a solid?? I have talked to some people and they seemed to have never heard of such a technique? I also seem to recall reading something about this in my overhaul manual?
Thanks, Terry
Thanks, Terry
