My AIM calls for 1 or more spacers between the water pump hub and pulley: GM3740523. No other specs. Is this a "try it until the pulleys align" or is there some other reason for it (them)? If I can't find a repro/replacement, will 5/8 flat washers suffice? Any insight or info is, as always, deeply appreciated. I CANNOT believe I am having so much trouble with a fan assembly!! just part of the fun...Thanks and regards...Joe
C3 Fan Spacer
Re: C3 Fan Spacer
Joe-----
How you deduced that it works is how it works---add spacers between pulley and waterpump hub until you achieve proper pulley alignment.
The GM spacers are discontinued. However, you can obtain spacer kits (3 different shim thicknesses per kit) as manufactured by Moroso and others. Or, you can make up spacers from sheets of brass shim stock. DO NOT use washers.In Appreciation of John Hinckley- Top
Re: C3 Fan Spacer
YOU ARE THE MAN! I will track them down, and especially thanks for the warning about the washer. I thought I found it at Paragon, but their description of the application was not what I needed...Thanks again...regards...Joe
PS: it looks like the spacers are drilled for the fan studs?..jt- Top
