on the carb on my L72 it just flops around. i assume it connects to some thing or has a spring load on it to engage it. can any one give me input on this, thaks,bill
fast idle cam question on holley
Re: fast idle cam question on holley
johns picture is exactly as my set up is. what i cannot see is what is behind the choke ro mount. the cam just swings in place and has nothing to bring it up to engage the choke set up. i suspect it is installed wrong or a spring is missing,bill- Top
there is a round projection on the back side of the cam that pushes up on the choke arm mechanism to close the choke. if this projection is installed above the choke arm mechanism it will not close the choke plate- Top
Bill,
With the choke not engaged, the cam will loosely swing up and down. It only engages by a lever next to it which holds one end of the rod which goes to the choke plate in the carb. Closing the choke plate will pull the lever up, which pulls the cam up. You don't need the the spring or lower rod attached to verify this operation.- Top
sorry i got that backasswards the choke
mechanism pushes up on the fast idle cam not the way i posted.you will not have fast idle if the projection on the plastic cam is not in the correct location above the mechanism. i should not depend on my memeory.- Top
