C3 shifter - NCRS Discussion Boards
C3 shifter
  • Bob I.
    • November 9, 2006
    • 265
    C3 shifter
    When I replaced the transmission mount. I unbolted the shifter from the crossmember now I can't get it to go into reverse. I checked the cable to the steering column it seems fine.
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: C3 shifter
    Bob
    Unhook the cable at the steering column and see if by moving the lever on the column you can get it in reverse. If this does not help make sure it is installed like it was before you started and adjust the linkage as per the manual.
    Lyle
    Lyle
