1976 Floor Pan - NCRS Discussion Boards
1976 Floor Pan
  • Tony H.
    • May 31, 1993
    • 537
    1976 Floor Pan
    A friend of mine has a rust problem at the seat belt well beneath the seat. It looks like the removal of the corroded seat belt retractor will leave a big hole that will need to be repaired. That repair patch will have to have a nut welded on the back side for the the retractor bolt. That is, if the whole floor pan isn't replaced.
    Any suggestion for a non-NCRS restoration and non-extensive/expensive but still adequate repair? What is the thickness of the metal used in the floor pans of 1976 Corvettes? Could a riveted and metal epoxy repair work here?
    Tony
  • Harmon C.
    • August 31, 1994
    • 3228
    Re: 1976 Floor Pan
    Tony
    If you can make a patch back to good metal that is as strong as original and you are happy with it that should ok. Check the thickness of the old material.
    Lyle
    Lyle
