1962 340HP had dual point mech only advance distributor 1963 340HP had single point vac advance distributor. What are the Pro and Cons other than judging points ? My understanding is the vac adv distributor is more drivable and that both distributors have a maximum of 20 degrees of mech adv? My 1962 340HP engine is missing the dual point distributor. During a recent rebuild I had flat top pistons installed to reduce the CR to 10:1 but everything else is the same. The distributor I have is correct for the 250/300HP engine. Any help in understanding this subject will be greatly appeciated. Thanks
Jeff
Jeff
