My '62 had front coils that made the car sit way to high. I like the look with earlier HD coils, so I had a new pair made by Coil Spring Specialties that are one inch lower than the standard '62 coil.
As you can see in the snap, the top of the tire is now even with the top of the wheel opening.
I have to go for an alignment, will I have caster and camber issues with the shorter coils? I understand that I can add another caster plate if needed, anything I can do if the camber won't fall within spec?
Paul
Paul
