i suspect the timing mark on my harmonic balancer is not accurate i would like some input as to determine the correct location on the balancer. the method i used was to hold my finger over the plug hole and watch for full compression and taking note of the marks location. it seems to be at the top of the plate about 16 degrees off. is there a way to more accuratly determine this. i am reluctant to use a wire rod to follow the piston as when i tried i found it hard to follow as they are not flat top pistons. it is a L72, i suspect this to be the cause of my stumbling issue as advancing the timing corrects it. bill
timing mark off?
Re: can you explain piston stop?
Bill,
A piston stop is a simple depth gauge device that threads into the spark plug hole. It provides an accurate reading of piston TDC without fear of damage or scoring by poking a wire or having a pencil break off inside the cylinder. They are cheap to buy and may even be available for loan at places like NAPA and Autozone.
For reference Summit Racing has several. Here is a link to one:
Take your time...you waited this long!
Mike- Top
Try this link instead. If this doesn't work just search on "piston stop"
- Top
Re: GM sells a nice piston stop...12364087
You can't beat the price...$9.09 through GMPartsHouse.com. Of course, the shipping will probably be more than half the price.
GMPartsHouse- Top
$8.01 at GM parts Direct
http://www.gmpartsdirect.com/results.cfm- Top
A Good Example Of...
Why GMPartsDirect Never Gets Any Orders From Me...I always compare SHIPPED prices when buying parts on the internet. GMPartsDirect shipping/handling charge for 12364097 is $9.95! Final shipped prices: GMPartsHouse = $17.04; GMPartsDirect = $17.96
In fact, if you're willing to wait a week or so, always compare internet shipped prices with the price your local dealer quotes. In this case, you can probably save money by buying at the dealer...GM list price is only $11.00 FOB his parts counter (assumes the "gouge" is not in). Of course, internet orders are delivered to your door, and you'll have to drive down to your dealer at least twice to get it...six of one, half dozen of the other.- Top
