Oil Pump C2 L71? - NCRS Discussion Boards
Oil Pump C2 L71?
  • Robert K.
    • June 30, 2001
    • 212
    Oil Pump C2 L71?
    Can anyone identify the following:
    Oil Pump number...(top half - bolts to the piece below which houses the impeller
    with 5 larger size machine screws which have a "straight slot"):
    3906829 with a "GM 20" Logo
    Oil Pump Number...(bottom half - body where impeller is):
    3904828 with a "GMT"
    I've looked pretty closely and these appear to be the numbers - I'm very sure of the 3904828 #......
    Re: Oil Pump C2 L71?
    Bob------
    There's no way to positively ID the pump assembly PART NUMBER from the casting numbers which you provided. However, the pump ASSEMBLY is very likely one of the following:
    1) GM #3904826-----67-69 with special high performance big block, including L-71. Also SERVICE for 65-66 with SHP;
    2) GM #3904827-----67-70 except SHP and HD.
    It could also be other pumps, but the above are the most likely.
    You could tell the above 2 pumps apart by doing the following: remove the oil pressure relief spring from the pump. Inspect the spring as follows:
    24 coils, 2-7/16" free length, 5/16" OD, with light green stripe= GM #3904826
    27/64" OD, 2-1/2" free length= GM #3904827
