1965 Delco Front Shocks ID - NCRS Discussion Boards
  • William O.
    • April 30, 2001
    • 355
    I have a pair of Delco Shocks Dated 8-28-65 with a part number of 5557395. Question: Are they orginal or replacment shocks and what car were they made for?
    Thanks.
    • 43193
    Re: 1965 Delco Front Shocks ID
    William----
    The part number is not a part number originally used for any C2 or C3 Corvette. If the shocks are configured in all ways like a C2-C3 Corvette, then they MAY be a Delco replacement shock. However, I can find no reference for that part number.
    • Loren L.
      • April 30, 1976
      • 4104
      Bill, first realize that the shocks were
      "julian" dated, not the system that you recite.
      Here are the markings on my 2 shocks, off of Vin #23561 - all of the stampings are on the BOTTOM portion of the shock:
      "PLIACELL
      3186906 34-65
      DELCO PRODUCTS DAYTON OHIO U.S.A."
      The other shock is maked identically, except that the date is "98-64"
      • Rob M.
        • June 30, 1999
        • 171
        My Project Pictures
        http://temp.corvetteforum.net/classics/l78vetteman/
          Re: What about judging points
          Rob -
          You'd lose 20% for the date, and 20% for configuration; assuming installation, completeness, and finish were correct, that 40% would be two points. Front shocks and bushings only carry five originality points.
            • 11608
            You're assuming that the chassis judge can even SEE the name and the date. If it were me I'd paint them the correct gray, attach labels and install them so the name is "less obvious." Then hope you have a "less than lean" chassis judge who can't see the writing and gives you full credit.
            Yes, it happens.
            Patrick
