I have a February 1969 with windshield and headlight washers. On the passenger side of the pump there is a three port valve. On the driver side there is another valve that is in bad shape which is supplied from the three port valve. All of the ports are capped or they are conveying water from the three port to the other valve. When I turned the washer on the other valve shot water out of the front via a hole. No nipple here, or at least there is one now.
Question: Do I have a three or five port washer?
Question: Can I obtain a replacement for the valve on the drivers side? What is it, what is it called?
Question: Where can I get some good drawings, etc. that will assist me?
