1969 SB PCV grommet - NCRS Discussion Boards
1969 SB PCV grommet
  • Bill Stephens
    1969 SB PCV grommet
    My 1969 350/300 had chrome valve covers when I bought it, with a set of orange-painted steel ones that I believe are the original. I repainted the steel covers and put them on, but the grommets for the PCV and vents were too big. The holes on the chrome covers are about an inch and a quarter, the holes in the steel covers are an inch.
    Which one of these is correct? This car has had a lot of after-market stuff put on and I'm trying to move it back to original. I'm not sure whether I just need new grommets (none of the suppliers give any dimensions on theirs) or new elbows, or the steel valve covers are wrong.
    Thanks in advance for your help.
    Re: 1969 SB PCV grommet
    Bill-----
    The 1" holes are correct. You require grommets currently known as GM #14091870. They are still available from GM for a current list price of $2.74/each. The original grommets, GM #3923256, were configured slightly different, but the 14091870 will function perfectly.
    The connector pipe (elbow) should fit the above-referenced grommets. If it doesn't, then you need a GM #3923260. This is the original part number and it's still available from GM for $9.67/ea GM list.
    • Bill Stephens
      Thanks Joe. Helpful as always.
