'72: Removing underbody seat belt brkt - NCRS Discussion Boards
  • Patricia Brown
    Hello,
    I have a damaged seat belt bracket-the one under the floor (NOT the one in wheel well). I removed all 7 rivets successfully, but the bracket will not come off, and I suspect it's also glued on. Is that correct? Any way to remove it without damaging the floor fiberglass?
    Thanks!
    Patricia
  • Chuck S.
    • April 1, 1992
    • 4668
    Re: '72: Removing underbody seat belt brkt
    Actually, I think you still have a few rivets to go...I count four each side in the floor where the cable ends attach, and two each tunnel side where the seat belts attach. I found no adhesive on this part; once you get all the rivets out, it should fall free.
    • Harmon C.
      • August 31, 1994
      • 3228
      Patricia
      I have seen some adhesive in the bottom of the bracket. I would tap it with a hammer to see if it will come loose after all the rivets are out.
      Lyle
      Lyle
      • Dick W.
        • 10483
        I agree with Lyle, I have seen a few with adhesive, not all though. If the tapping does not loosen it up, take a SHARP putty knife and carefully break the bracket loose from the floor pan.
        Dick Whittington
        • Patricia Brown
          Ah, I better clarify; I'm referring to the outer seat belt bracket, not the upside-down U-shaped one in the tunnel. The one I'm working on is near the rocker panel.
          I will have to keep trying with a sharp putty knife; the trouble is the glue seems to be deep in the center of it, and I'm having a tough time gettint to the glue.
          Patricia
          • Harmon C.
            • August 31, 1994
            • 3228
            Patricia
            I would use some heat on the metal if it is stuck that tight. I thought that was the bracket you was working on. Most of the ones I removed were badly rusted and came off very easy.
            Lyle
            Lyle
            • Patricia Brown
              Lyle,
              Thanks for the idea of heat; I'll see if that helps.
              Patricia
              • DAVE CRAIG
                WHEN YOU REPLACE THE BRACKET WHAT WOULD YOU USE TO REMOUNT ALONG WITH THE RIVETS
                • Dick W.
                  • 10483
                  Dave, turn off your caps, all caps is considered shouting. I would use a two part adhesive such as a 3M or SEMS product with the rivets.
                  Dick Whittington
                  • DAVE CRAIG
                    thanks and sorry about that
