I just installed the door panels on the 58, and the door knob rod protrudes about 5/8" away from the panel. It doesn't look right to me, but there doesn't appear to be much room for adjustment inside between the window frame. What's the accepted distance for this rod to stick out? Thanks.
C1 interior door open mechanism
Re: C1 interior door open mechanism
Glenn,
What you are describing is typical, don't worry about it. One thing I would suggest though is using the '61-62 black plastic disc between the door panel and door. I used them on mine and they hide the mechanism nicely.
Looking forward to seeing it in August. Best Regards.............Mark- Top
