Re: duke what do you think of this??
I see why people try to make full roller rockers out of aluminum. But, I heard aluminum can't handle it for the long haul. Based on what you have said, I can't see how a full roller rocker like comp cams wouldn't limit the valve train. You can't hide that tip and the rest of the lifter body can't be significantly lighter. At least I can't immagine it to be. I will try to ask those guys and see what they say. I am sure the mid-section of the rocker is compareable or less, but that has very little effect on what is going on out at the tip when things are flying. So full rollers have there application on gorilla springs when they can compensate for the added weight of the rocker tip. What a drag, burst my bubble I would like to measure the torgue/force differences required to rotate a conventional rocker arm vs. a full roller rocker arm set-up. Does the reduced friction compensate for the added weight of the rocker tip in allowing the valve spring to force the valve shut?? It would be helpful to actually see the hp/torque curves on two identical engines (designed to develope peak hp/torque at around 5500 RPM) but with the different valve trains to compare what is really occuring at 5000-6000 RPM. Thanks for all the advice and insight, Terry
