Could someone tell me the assembly date for a 54 Vin#E54S003234 and or where the information can be obtained.
54 Born date
- Top
- Top
Re: 54 Born date
If you are using the NCRS website birthday calculator, you need to subtract 1000 from you serial number. That tidbit is in the fine print. If you don't subtract the 1000, the birthday calculator will add about a month on to your estimated build date.
My 54 is #3279. Engine Serial Number of 0601431. Estimated build date is June 1, 1954. But I think it was a bit later than the estimate date. My car has only 42k miles and still has quite a few original parts. Several of the parts are dated June 1 or so. And the carb tags (original) are stamped in June.
Russ- Top
Re: 54 Born date
My car, number 3223, has a E174 casting date for its block and a 0390437 sequence number. The C1 registry shows the same birthday as yours, May 31, but I believe that it was a late June car based upon what I know about others that are close to my serial number.- Top
