I'm looking at a local 67 corvette coupe for sale.The car has black interior.The only option that I think would effect the trim tag is the fact that it has power windows.Should a 67 with black vinyl interior have an ECL code for the power windows.If so what should it be.I've referenced Nolan Adams book.But I'm still not sure. Thanks for any help.
Real power window car?
Re: Real power window car?
Hi Louis No ECL codes for black (STD) interior.There are a couple of thing you could check to see if it orig. had P/W. The 67 is the first year the P/W windows work only with the key turned on. The earlier cars work without the key. If they were put in a long time ago the power window relay userly didnt get installed. Check the door conduits, look at the wiring for tape etc. Phil 8063
..- Top
