When pressing the clutch on my '69 car the clutch bearing is making a sort of grinding noise. Sander told me it likely needs replacement. Two questions:
1) Could it be it only needs greasing and can this be done without pulling the tranny (through the clutch boot on the bellhouse)?
2) If the bearing needs replacing what is the procedure to do this? This service manual is not crystal clear on the procedure and I was wondering if any alternative description is somewhere (on-line) available?
thanks,
Rob.
thanks,
Rob.
