C2 hood gasket. - NCRS Discussion Boards
C2 hood gasket.
  • Bill S.
    • January 31, 2007
    • 396
    C2 hood gasket.
    should i brush glue on hood or gasket? am i correct in assuming it rest against the rise inside hood and flat of hood meaning glued on 2 sides in a 90 degee channel? how far down on each side did it extend, and where they even on both sides from the factory? and last, is yellow 3M correct?
  • Larry L.
    • May 31, 1993
    • 101
    Re: C2 hood gasket.
    My orig. 66 has nice swipe of yellow glue complete with brush marks. The weather strip could be glued on back too but there is no evidence of glue on side of weather strip. About two inches down the side there should be a hole that is used to hold side of weather strip in place. Each end. Metal fastener with a pan head and a bow legged metal frame - same on that is used in the convertable top header is used to hold weather strip in place - most have rusted off so you don't see many with the tack in place. Look at orig. hoods for the location of the hole.
    • Joe R.
      • March 1, 2002
      • 1356
      Re: C2 hood gasket.
      Based on what I have heard and on previous discussions here on the TDB, I believe that the fastener in each end of the hood weatherstrip was only installed on St. Louis bodies, although the current judging guide does not make this distinction.
      • Bill S.
        • January 31, 2007
        • 396
        Re: C2 hood gasket.
        that is really interesting, never came across this before. so the one i bought is not like the original sans a tab? how far down each side does it extend?
        • Bill S.
          • January 31, 2007
          • 396
          Re: C2 hood gasket.
          i have an AO smith.
          • Stephen L.
            • May 31, 1984
            • 3148
            Re: C2 hood gasket.
            Bill, If youhave holes in the hood for the ends of the weatherstrip then you'll probably need to pin clips. LIC has them.
            This photo shows the typical length for my 67....
            THe pin is about 1/2 inch from the end of the stripping
            • Robert T.
              • May 31, 1993
              • 346
              Re: C2 hood gasket.
              I thought these fasteners were only used on the 67 hood weatherstripping. In fact LIC list them for use only on a 67. Am I wrong yet again.
              Bob
