Plug Wires on 72 350 - NCRS Discussion Boards
  • Greg Sullivan
    Folks I have 72 350 k motor and I am attempting to dress the plug wires correctly. I don't understand how the plug wires should attach to the clips on the oil pan. Further under which spark plug should the oil pan clips be located?
  • William C.
    • May 31, 1975
    • 6037
    Re: Plug Wires on 72 350
    Look at the assembly namual UPC6 Page B^. The clip on the pan rail is about at the center of the pan, near the water drain plug on either side of the block. The wires run thru the clip, it encircles them in it's "U" the closed end of the U is facing the ground if properly installed. It is totally different from the clips shown in View A, they attach to the base of the front heat shields.
    Bill Clupper #618
