63 SB engine - NCRS Discussion Boards
63 SB engine
  • Rainer S.
    • May 31, 2003
    • 468
    63 SB engine
    I have a SB 327, 360 HP engine in my car. On the front, top of the block, almost center , there is a hex (for an allen wrench) 1/4 NPT plug. Someone told me that the plug is incorrect. Is that so ? It may have been replaced by the engine rebuilder...
    Rainer
  • Dennis C.
    NCRS Past Judging Chairman
    • January 1, 1984
    • 2409
    Rainer, Believe that is usually a male square...
    ...pipe plug - however, I thought the thread was 1/8" npt, not 1/4".
    • John D.
      • December 1, 1979
      • 5507
      Re: 63 SB engine
      Ranier, As Dennis said the plug is 1/8" pipe. But the head of the plug is square. Those plugs readily available at NAPA although the new ones don't have the slight recessed head of the old original. In any case it's not an allen screw. I don't know the purpose of this plug. But it's an easy way to spot a Flint engine from a Tonawanda one. The T's don't have the plug. Plug painted orange of course.
      • Joe C.
        • August 31, 1999
        • 4598
        Re: 63 SB engine
        Plug is for a test hole drilled into the oil gallery.
        Joe
        • John D.
          • December 1, 1979
          • 5507
          Re: 63 SB engine
          Joe, Thanks. Haven't heard that answer for a long time. John
            Re: 63 SB engine
            Flint V-8 drilled the front oil gallery junction from the outside, and that's why their blocks have the hole and the plug. The Tonawanda process to create the junction was different and didn't require the external hole.
            • Rainer S.
              • May 31, 2003
              • 468
              Re: 63 SB engine
              You are correct, that is 1/8" NPT. Will have to replace the plug. Thanks for the ic and comments..
              Rainer
              • John D.
                • December 1, 1979
                • 5507
                Re: 63 SB engine
                John, One time I caught a guy cheating. He put a plug in his Tona block. He didn't know the spacing was different on the ribs. Also he didn't know that the block he counterfitted had a clock on the rear. It was pretty funny. John
                • Robert Willis
                  Re: 63 SB engine
                  I saw that hole used for oil pressure to and air compressor on a dump truck of early 60s vintage. Test hole or an extra oil feed, other than Corvette ???
                  Bob
                  • Mike M.
                    • May 31, 1974
                    • 8365
                    Re: 63 SB engine
                    agree with bod as we had an old chevy dump truck with air brakes that utilized the site in question to lubricate the air compressor.mike
                    • Robert Willis
                      Re: 63 SB engine
                      In 1955 the 265 used the same oil pressure location was used to feed the remote oil filters on passenger cars. I think the filters were to tall to clear the Corvette hood.
                      Bob
