Hello all.
Looking for some guidance on what might be wrong with my 66 300 HP. When I cruise thru the neighborhood, under 20 mph and under 2000 rpm, the car won't cruise smoothly and has some "jerkiness" to it. Almost like I am stepping on the gas in short rapid bursts. I don't see a difference in rpm but I can feel the uneven speed.
I suspected ignition so here is some data. Initial timing (vac line plugged)11* BTDC. I previously bumped initial timing to achieve 36* WOT. Spec is 6* BTDC.
Idle vacuum is 17.5" both with a "Tee" in the vacuum line and without. With the vacuum can connected and at idle the total timing is 28*.
The spec for my distributor is 16* vacuum advance at 12" so it appears to me I am getting full vac advance ( 28-11= 17)at idle. IIRC Duke suggests full vac advance 1-2" below idle vacuum. I am using a Napa VC680 vacuum can which is spec'd at 16* advance at 16" vac. The above measurements were taken without restraining the centrifugal weights in the distributor so maybe they are worthless. Spec on 111153 distributor is 0* centrifugal advance at 900 rpm so in theory the centrifugal weights have not yet begun to advance.
I do not have a Mity Vac so I cannot spec the can directly.
I am assuming that at low cruise speeds my engine would develop 17.5" vacuum.
I tried setting the initial timing back to 6* BTDC but no significant results
I would appreciate any feedback
Randy
Randy
