Block ID - NCRS Discussion Boards
Block ID
  • Gilbert Rasco
    Block ID
    On the ID pad of my 1967 corvette big block there is a number that I am curious about the engine Id is 7103741 date code is F1024JE but on the far left of the pad is CE50956 does anyone know what this might be, and how will it affect the NCRS judging of my engine?
  • Gary Schisler
    Re: Block ID
    "CE" is a Chevorlet engine replaced under warranty, usually by the dealer. The other number beside the CE is generally accepted as the sequence number for that engine, not a serial number or build date. It is probable that your original engine was replaced under warranty.
    • Edward M.
      • November 1, 1985
      • 1916
      Re: Block ID
      The CE50956 indicates that this is a service replacement block. I suspect that the engine was replaced, probably under warranty. I have seen other cases where the dealership stamped the engine with the VIN derivative. I have never seen a case where the dealership also stamped the assembly date and suffix code, but this may have happened here.
      Can you tell us what the casting date of the block is? Also, what is the body build date of your car? This may help make things clear.
      Did I understand correctly that the VIN derivative (7103741) is also stamped into the front pad? The assembly date of 1024 (October 24th) seems to correspond with the expected assembly date of 1967 Corvette # 3741.
      Let us know what you find out about the casting date?
      • gil rasco
        Re: Block ID
        the vin number is 194677s 103741 the CE860956 is on the fender well side of the id pad in the middle is the 7103742 number and it is smaller case than the other two numbers the other number is F1024JE. the casting number on the block is 391632F & GM3
          Re: Block ID
          What's missing here is something to talk about.... All I see is a statement of 'fact' about something....
          • gil rasco
            Re: Block ID
            look DS re: means a response to a question which was a prat of the thread but is now missing go find somthing else to do
