C2 Stering Box Parts - NCRS Discussion Boards
  • Dave K.
    • November 1, 1999
    • 951
    I'm considering a rebuild of my 66 non power steering box and would like to know where to get a bebuild kit. It appears that LIC no longer has the parts.
    Dave K.
  • Joe C.
    • August 31, 1999
    • 4598
    Re: C2 Stering Box Parts
    • Dave K.
      • November 1, 1999
      • 951
      Thanks Joe!
      Dave K.
      • Gary Schisler
        Dave,
        You just had that car judged after an extensive rebuild and resto and NOW you want to tear into the steering. Go drive that sucker somewhere!
        Gary
        • Dave K.
          • November 1, 1999
          • 951
          Gary,
          Have some play in the steering. I just wanted a source for parts if I can't adjust the play out. Prepping for PV next.
          Dave K.
          • Gary R.
            • April 1, 1989
            • 1796
            Play in the box usually comes from a couple of areas.
            1- incorrect adjustment- causing wear on center and wrecking the gears
            2- lash screw gap incorrect- can be shimmed with the shims in the kits
            3- sloppy bushings. The original bushings have about .010" sideplay in them. The kit bushings will cut that to about .005. I machine and fit bushings to .002-.0025 to give the best fit. If you have access to a lathe you can do the same or just use the kit bushings. I think we all sell the same kits as well. You'll need to get a new pitman arm washer and nut as well.
            • Gary R.
              • April 1, 1989
              • 1796
