Re: the price of gasoline is in line with inflatio
I remember as a kid the "gas wars" of the fifies - down to 19.9 cents at one time in Seattle. We were awash in petroleum, and it was cheap. They practically gave away diesel because aviation was still 99 percent recips, and there was a big surplus of the distillates that were too heavy for gasoline.
Back then there were still "distillate engines" that burned a low octane blend that was closer to diesel than gasoline. They were low compression spark ignition engines (usually multiple spark plugs and ignition systems because the stuff was so hard to ignite) with carburetors that were hard to cold start and not very efficient, but the fuel was a dime a gallon to farmers to run their tractors.
I also remember that computers cost several milllion dollars, and you could count the number installed on not much more than the fingers of your two hands.
A new '07 Corvette costs about ten times more than a new '57 and the gasoline to run it is also ten times more - pretty good benchmark!
Think of how different the world will be in another 50 years, but chances are, like most "futurists" from past generations, your scenario won't even be close to reality.
