63 SWC fuelie - NCRS Discussion Boards
63 SWC fuelie
  • Rainer S.
    • May 31, 2003
    • 468
    63 SWC fuelie
    I just got a new 5 X 17" radiator fan from one of the vendors. GM replacement for 60-67, non A/C. It has flat rivet heads and a flat hub.
    The JM says, that I should have a (5) blade fan with a round rivet heads, round-ish hub and rounded blades for early 63. My car had a (7) blade fan with round rivet heads, roundish hub and sqare fan blades. (apears to be for A/C).
    I want a used the correct fan for judging.
    Are older fans available ? (I could trade my A/C fan...)
    What deduction would I have to take, if I should stay with the new GM replacement unit ?
    Rainer
  • Andy C.
    • May 31, 1987
    • 71
    Re: 63 SWC fuelie
    All 63 corvettes used a 5 blade fan with the letter H stamped by the center hole. The diameter of the blade was 17 1/4" with Round head rivets and it had 5 blades for ALL applications including air cars. Used originals are around for $50 - $100. I would be careful and buy a good one that is not bent up or pitted. If you lay the blade on a flat surface the trailing edges of each blade should completely touch the surface. The fan blade I do believe was painted Gloss black. I hope this helps? Andy
    • Rainer S.
      • May 31, 2003
      • 468
      Re: 63 SWC fuelie
      Andy,
      That confirms what I wanted to know. I will cont to look for a good orig one.
      Good way to check it, too.
      Rainer
      • Rainer S.
        • May 31, 2003
        • 468
        Re: 63 SWC fuelie
        Andy,
        Rainer
