Brakes Carb 66 Vette - NCRS Discussion Boards
  • Edward M.
    • May 31, 1993
    • 17
    1966 Corvette 327/300 4 speed Oct 65 car
    Need to know the arrangement of the gaskets between the cast iron intake and the HOLLEY CARB. Also what are the front casting #'s for the brake calipers and are ther any date codes on them.
    Thanks for your response.
    Ed
    Re: Brakes Carb 66 Vette
    Ed-----
    Gasket goes on first, stainless steel baffle next, and carburetor on top.
    Front brake caliper halves were casting numbers 5465952 and 5465954. There is what appears to be a date code. However, it includes no reference to year, so it's fairly meaningless. It's not a judged item, either.
      Ed-----
      • Gerard F.
        • June 30, 2004
        • 3803
        Ed,
        On the carb, the gasket goes against the manifold and the SS baffle goes against the carburetor base. If you have the carb off and the manifold has a "hot slot", consider plugging the exhaust gas holes in the hot slot. See this post from the arhives:
        Jerry Fuccillo
        #42179
        Jerry Fuccillo
        • Gerard F.
          • June 30, 2004
          • 3803
          Ed,
          Jerry Fuccillo
          #42179
          Jerry Fuccillo
