If this is your first visit, be sure to
check out the FAQ by clicking the
link above. You must be an NCRS member
before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below.
I have discovered a lazy headlight and a wiper door that is not opening. The check valve has been replaced (though nothing appeared wrong with the other one), the seals have been replaced on the vacuum pots and both worked well 1000 miles ago. Any suggestions??
I would check out the system till I found the leak. Theirs not enough information to pin point the problem. I use a tank and an A/C pump to supply a source of vacumn so I can hear the leaks.
Lyle
Lyle
Understand from the vacuum routing path that the RH headlight and wiper door SHARE a common vac servo path, separate from the LH headlight door. So, leak(s) anywhere on that side of the system will affect BOTH devices...
Also, don't overlook the vac system filter while you're diagnosing things. A lot of folks don't bother doing preventive maintenance (filter was intended to be replaced every year or so) and a clogged filter can result in 'squirrely' vac system operation when there are no leak(s)...
I've found the best and easiest way to diagnose a leak is to hook a long amount of tubing to a vacuum nipple on another running car and plug the other end into your main vacuum hose on the intake. If the outside car is far enough away, it will be quiet enough for you to check each vacuum relay, actuator, hose, etc. and listen for leaks. Works like a champ. Patrick Moresi #45881
We use cookies to deliver our services, and to analyze site activity. We do not share or sell any personal information about our users. For additional details, refer to our Privacy Policy.
By clicking "I AGREE" below, you agree to our Privacy Policy and our personal data processing and cookie practices as described therein. You also acknowledge that this forum may be hosted outside your country and you consent to the collection, storage, and processing of your data in the country where this forum is hosted.
