C-1 1959 Intake Manifold Gaskets - NCRS Discussion Boards
  • Jimmy J.
    • May 31, 1988
    • 304
    Re: C-1 1959 Intake Manifold Gaskets
    I was also told at the speedway Regonial that the round end of the tab should be squared off. Has anyone heard this before? Thanks for responding. Jimmy
    • Jimmy J.
      • May 31, 1988
      • 304
        • 11608
        #18
        John,
        I would suggest that there are two sets of tabs, and it will depend on the person as to which one you are discussing.
        One is the rounded one that I am showing in my picture, and located in the middle of the long gasket. As aftermarket gaskets are straight across in this location, there is no tab on them.
        The other is the square tab with the GM letters on the rubber end gaskets. Bill Clupper has kindly provided a picture of that tab.
        Note that Paragon's description of the tabs is the one I am using. In addition, it's generally the tabs we look for in 70-72 judging that I do. So, that is my frame of reference. I would suggest that if your 63 has NOS gaskets, you have both sets of tabs on your car.
        Patrick
          • 11608
          #19
          John,
          Patrick
          • John D.
            • December 1, 1979
            • 5507
            #20
            Patrick, I agree with you explanation. Two sets of tabs. And there are variations on the configuration of these tabs. Once you put a NOS up against a replacement you will see a big difference. John
            • John D.
              • December 1, 1979
              • 5507
              #21
              • William C.
                • May 31, 1975
                • 6037
                #22
                Yes, 283 used a tab that was rectangular, not round as the '63-up cars used. I believe the '62 also used the square tab.
                Bill Clupper #618
                • Dennis C.
                  NCRS Past Judging Chairman
                  • January 1, 1984
                  • 2409
                  #23
                  Agree w/Clup on '62 squared off tab... *NM*
                  • Mike M.
                    • May 31, 1974
                    • 8365
                    #24
                    Re: Agree w/Clup on '62 squared off tab...
                    agree with clup and the dipstick. mike
                    • William C.
                      • May 31, 1975
                      • 6037
                      #25
                      WOW! all agree?? *NM*
                      Bill Clupper #618
                        • 11608
                        #26
                        Bill,
                        Rubber tab, or the side gasket tab?
                        Patrick
