Seat track carpet cut outs - NCRS Discussion Boards
  • Tim Sargent
    I have a set of what I think are original 67 carpets (they still have the Stevens tag on them). The cut-out for the seat tracks are four flaps on each side just covering the front and rear footprints where the mounting bolts go into the tracks. I am installing new carpets and the AIM and Judging Manual indicate (if I am interpreting them correctly)the cut-out flap is the entire length of the seat track rather than just the at the footprint areas. Which is the more correct cut-out pattern?
    Thank You
  • Kevin M.
    • November 1, 2000
    • 1271
    Re: Seat track carpet cut outs
    Your originals are correct.
    Kevin
    • Alan Drake
      Tim,
      cut as little as possible, then if you loose more points than necessary you can cut more if desired. Once cut its tuff to put back.
      • Stephen L.
        • May 31, 1984
        • 3148
        Tim, could you post a photo of the cutouts? The judges look for a hinged flap on the front seat mounts only. Your description indicates the rear seat mounts are also hinged cutouts rather than just a cutout.
        The cutouts are definitely NOT running the length of the track.
        Steve
        • Tim Sargent
          Steve
          I will be glad to send you a picture to your E-Mail, if you provide it, and you can post it if you like
          Thamks Tim
